Group: DynoMotion Message: 792 From: likleong Date: 12/19/2010
Subject: KFlop interface with Mitsubishi MR-J2S servo system
Hi TK,
I would like to drive the MR-J2S servo system by KFlop open collector output, according to servo system manual, the input side internal circuit look like the below diagram.
R=1.2K opto-coupler
24V >-----^^^^------|>|-----------o Step
(Open collector INPUT)
GND |-----------------------------o GND
I am not sure whether the open-collector output of KFlop can drive it or not, I am afraid the current may too high, do you have any idea about this? Thanks.
Best regards,
Benny
Group: DynoMotion Message: 794 From: Tom Kerekes Date: 12/20/2010
Subject: Re: KFlop interface with Mitsubishi MR-J2S servo system
Hi Benny,
No you can NOT connect 24V opto signals to KFlop Open collector outputs.  The outputs are diode clamped to the the 3.3V power, so they are limited to a max of ~4V.   This works when driving optos connected to +5V.
You didn't send any link to any Manuals for your MR-J2S.  Or what you are trying to connect to.   But I did some searches and might have found something similar.  They seem to provide an additional connection directly to the Anode so a lower voltage could be used.
Group: DynoMotion Message: 795 From: likleong Date: 12/20/2010
Hi TK,
The 24V source is not directly connected to the opto-coupler, there is a resister (1.2K) between then for bias purpose, just like the following diagram:
R=1.2K opto-coupler
(Connected to Kflop OC O/P)
I think is should be okay, right? What I am worry about is the max current that the open collector output of Kflop can handle.
Best regards,
Benny.
> Hi Benny,
> From: likleong <likleong@...>
> Sent: Sun, December 19, 2010 11:03:10 PM
> Subject: [DynoMotion] KFlop interface with Mitsubishi MR-J2S servo system
> Hi TK,
> below diagram.
> R=1.2K opto-coupler
> Best regards,
> Benny
Group: DynoMotion Message: 797 From: Tom Kerekes Date: 12/20/2010
Hi Benny,
The problem is that when the KFlop output goes "open" it is still diode clamped to 3.3V and can't rise above ~4V.
So when the KFlop output goes "open" and "closed" the output pin will switch between 4V and 0V.  Assuming an opto diode drop of 1V the 1.2K resistor will "see" either 23V or 19V.  So the current will be either 19ma or 16ma.  The opto will be on in both cases.  Also KFlop outputs are limited to 16ma.
Group: DynoMotion Message: 799 From: likleong Date: 12/20/2010
Hi TK,
Is there any way to solve this problem? Thanks.
Best regards,
Benny
> Hi Benny,
> Sent: Mon, December 20, 2010 5:23:07 PM
> Subject: [DynoMotion] Re: KFlop interface with Mitsubishi MR-J2S servo system
> Hi TK,
> R=1.2K opto-coupler
> Best regards,
> Benny.
> > Hi Benny,
> >of
> >trying
> >so
> > From: likleong <likleong@>
> > Hi TK,
> > below diagram.
> > R=1.2K opto-coupler
> > Best regards,
> > Benny
Group: DynoMotion Message: 800 From: Tom Kerekes Date: 12/20/2010
Hi Benny,
Do you have a manual?  What pins are these?
If you have access to the Anode connect it to 3.3V through a 200ohm
Group: DynoMotion Message: 801 From: likleong Date: 12/20/2010
Hi TK,
The related manual pages have been uploaded to Photo section, could you please have a look. Thanks.
Best regards,
Benny
> Hi Benny,
> Sent: Mon, December 20, 2010 7:28:38 PM
> Hi TK,
> Best regards,
> Benny
> > Hi Benny,
> >opto
> > Hi TK,
> diagram:
> > R=1.2K opto-coupler
> > Best regards,
> > Benny.
> > > Hi Benny,
> >The
> > >of
> >are
> > >trying
> >Anode
> > >so
> > > Regards
> > > Hi TK,
> >the
> > > below diagram.
> > > R=1.2K opto-coupler
> >I
> > > Best regards,
> > > Benny
Group: DynoMotion Message: 802 From: Tom Kerekes Date: 12/21/2010
Hi Benny,
You didn't include a link to the manual but I found this:
Is that your unit?
I don't think that drive will accept Step/Dir inputs.
It only accepts quadrature input from a Manual Pulse Generator.  KFlop can only output Step/Dir not Quadrature.
But electrically it could be connected as:
Leave OPC disconnected.
Connect PG and NG to 3.3V
Connect KFLOP Open Collector to PP
Connect KFLOP Open Collector to NP
Group: DynoMotion Message: 803 From: likleong Date: 12/21/2010
Hi TK,
I am using the MR-J2S-40A, they have same input pin but it accept step/dir input. For your suggestion, is it possible to use the LVTTL output instead of open collector? Then, I can save a 3.3V DC source.
Best regards,
Benny
> Hi Benny,
> http://www.autocontcontrol.cz/rs/download/manual/Manual_MR-J2S-CL_GB.pdf
> Is that your unit?
> Sent: Mon, December 20, 2010 10:59:14 PM
> Hi TK,
> Best regards,
> Benny
> > Hi Benny,
> > Hi TK,
> > Best regards,
> > Benny
> > > Hi Benny,
> >clamped
> >will
> >The
> > >opto
> > > Regards
> system
> > > Hi TK,
> > diagram:
> > > R=1.2K opto-coupler
> >that
> > > Best regards,
> > > Benny.
> > > > Hi Benny,
> >outputs.ÃÆ'‚
> > >The
> >max
> > > >of
> > > > ~4V.ÃÆ'‚ ÃÆ'‚  This works when driving optosÃÆ'‚ connected to
> >+5V.
> > > > You didn't send any link to any Manuals forÃÆ'‚ your MR-J2S.ÃÆ'‚
> >Or what you
> > >are
> > > >trying
> > > > to connect to. ÃÆ'‚  But I did some searches and might have found
> >something
> > > > similar.ÃÆ'‚  They seem to provide an additional connection directly to
> >the
> > >Anode
> > > >so
> > > > Regards
> > > > TK
> > > > ÃÆ'‚
> > > > Hi TK,
> >output,
> > >the
> > > > below diagram.
> > > > R=1.2K opto-coupler
> >not,
> > >I
> >Thanks.
> > > > Best regards,
> > > > Benny
Group: DynoMotion Message: 804 From: Tom Kerekes Date: 12/21/2010
Hi Benny,
Yes That should work also.  KFlop could provide the 3.3V.
Group: DynoMotion Message: 805 From: likleong Date: 12/21/2010
Hi TK,
what is the max souce current of kflop LVTTL output? I am afraid it is not enough to drive the opto coupler.
Best regards,
Benny
> Hi Benny,
> Sent: Tue, December 21, 2010 4:20:13 AM
> Hi TK,
> Best regards,
> Benny
> > Hi Benny,
> > Is that your unit?
> >only
> > Hi TK,
> > Best regards,
> > Benny
> > > Hi Benny,
> system
> > > Hi TK,
> > > Best regards,
> > > Benny
> > > > Hi Benny,
> > >clamped
> >switch
> > > > between 4V and 0V.ÃÆ'‚  Assuming an opto diode drop of 1V the 1.2K
> >resistor
> > >will
> > > > "see" either 23V or 19V.ÃÆ'‚  So the current will be either 19ma or
> >16ma.ÃÆ'‚
> > >The
> > > >opto
> > > > will be on in both cases.ÃÆ'‚  Also KFlop outputs are limited to 16ma.
> > > > Regards
> > > > TKÃÆ'‚
> > system
> > > > ÃÆ'‚
> > > > Hi TK,
> > > diagram:
> > > > R=1.2K opto-coupler
> > >that
> > > > Best regards,
> > > > Benny.
> > > > > Hi Benny,
> > >outputs.ÃÆ'Æ'‚ÃÆ'‚
> > > >The
> > >max
> > > > >of
> > > > > ~4V.ÃÆ'Æ'‚ÃÆ'‚ ÃÆ'Æ'‚ÃÆ'‚  This works when driving
> >optosÃÆ'Æ'‚ÃÆ'‚ connected to
> > >+5V.
> > > > > You didn't send any link to any Manuals forÃÆ'Æ'‚ÃÆ'‚ your
> >MR-J2S.ÃÆ'Æ'‚ÃÆ'‚
> > >Or what you
> > > >are
> > > > >trying
> > > > > to connect to. ÃÆ'Æ'‚ÃÆ'‚  But I did some searches and might
> >have found
> > >something
> > > > > similar.ÃÆ'Æ'‚ÃÆ'‚  They seem to provide an additional
> > >the
> > > >Anode
> > > > >so
> > > > > Regards
> > > > > TK
> system
> > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > Hi TK,
> > >output,
> >like
> > > >the
> > > > > below diagram.
> > > > > R=1.2K opto-coupler
> > >not,
> > > >I
> > >Thanks.
> > > > > Best regards,
> > > > > Benny
Group: DynoMotion Message: 806 From: Tom Kerekes Date: 12/21/2010
Hi Benny,
Good point.  KFlop sources > 2.9V @ 16ma.  Sink < 0.4V @ 16ma
But the 5V tolerant I/Os have a 47 ohm in series.
You will probably need a buffer.
